Eric, or anyone with audio experience.....
Old May 11, 2007 | 12:51 AM
Frenchy's Avatar
Frenchy
Default RE: Eric, or anyone with audio experience.....
Well, my RCA cables aren't cheap ones, at 49.99 they better not be. ;-)
Also, the battery ground is fine...
The ground from the H.U. I need to do I guess...
At 80% volume I set my gain to where it was where I wanted it, and it was slightly higher than halfway up.
I'm guessing it's ground loop....
Off to work on that issue now...
At 10 freaking PM... last night I was working on it til 2am.
Nothing I don't do all the time as is.
Old May 13, 2007 | 02:47 AM
Frenchy's Avatar
Frenchy
How would one go about checking that?
Old May 13, 2007 | 03:20 AM
Frenchy's Avatar
Frenchy
I need new positive and negative battery terminals....
Can you hook me up Eric? I bought the ones from KnuKonceptz.com and they aren't that great, they keep stripping out, and my negative it isn't very tight, and my battery keeps dying because of it.....
Can you hook me up on a deal with a pos and neg with at least TWO 1/0AWG inserts and at least one 4AWG insert?
Old May 13, 2007 | 03:28 AM
Altair's Avatar
Altair
Dak attack!
ORIGINAL: Frenchy
My god Frenchy, what are you running for a total system?
Old May 13, 2007 | 03:34 AM
Frenchy's Avatar
Frenchy
A lot, I have an Orion 1200D that will be pushing a JL 13w7 at .75ohm so about 1350 - 1400 RMS, and my front stage I am running an Orion 4004 to my Clif Designs speakers, running 125 a side...
I have a 250AMP fuse, the thing is a long rectangular one...
I believe that it's an ANL fuse
