4.10 gears are installed
Old May 19, 2007 | 04:30 PM
mb18's Avatar
mb18
Default RE: 4.10 gears are installed
ORIGINAL: Frenchy
Just don't forget.. lol...
I wonder if this is messing with my MPGs... :-\
I won't. Just might be a few hours 'til I report back. I've got a good list of errands that I need to get done.
Old May 19, 2007 | 05:11 PM
Frenchy's Avatar
Frenchy
From what I've seen about 99% of v8's run around 1500 - 1700 rpms at 60 mph...
Oh well, I really need to get this fixed I guess...
Old May 19, 2007 | 05:28 PM
HankL's Avatar
HankL
Tire sidewall data on your truck?
Getrag trans nameplate data?
Does the sticker under the hood confirm that the differential ratio is 3.55?
Old May 19, 2007 | 05:43 PM
HankL's Avatar
HankL
With Getrag 238 six speed manual
and 3.55 differential gears
in sixth gear (0.79)
rpm of 2100 at 60 mph
would require 27 inch diameter tires.
If in 5th gear (1.00)
rpm in 2100 at 60 mph
would require 33.8 inch diameter tires.
Getrag 6 speed manual, model 238
used with the 3.7 V6 and 4.7 V8
1st - 4.23
2nd - 2.53
3rd - 1.67
4th - 1.23
5th - 1.00
6th - 0.79
Rev - 3.84
Old May 19, 2007 | 06:43 PM
Frenchy's Avatar
Frenchy
I know my truck has the 3.55.. I ordered it that way.. and my tires overall height are 29.7"
In theory, what SHOULD my tach read at 60mph?
Old May 19, 2007 | 06:50 PM
mb18's Avatar
mb18
OK, just back from the RPM test. Mine's running at an even 2000 RPMs, in 6th, at 60 mph.
Old May 20, 2007 | 11:10 AM
HankL's Avatar
HankL
The 2007 Toyota Tundra six speed auto trans drivetrain
combines a 4.10 differential gear with a 0.59 top overdrive gear
with 255/70R18 tires
The 2006 Honda Ridgeline combines a 4.53 differential gear
with a 0.53 top overdrive gear
with 245/65R17 tires
Questions every pickup truck owner should ponder:
If I want the fastest 0-60 mph time
what should my rpm be when I reach 60 mph in 2nd gear?
Does it make sense to have such a high overall gear ratio in first gear
that it just breaks the tires loose uncontrollably
if I try to launch the truck
with the engine rpms near the torque peak rpm?
If I can't launch with the engine rpms near the torque peak
am I using all that my engine can give?
What should my rpms be
as I cross the finish line of a quartermile?
If as a truck owner I don't care about quartermile acceleration
what should my rpms be in the 'real world'
at 75 mph as I accelerate onto a crowded interstate highway
from an on-ramp?
Old May 20, 2007 | 04:46 PM
mb18's Avatar
mb18
ORIGINAL: ericemery
wait, did hank answer a question with a question? lol I do see where he is coming from with it. Myself would look for the real worldapplication of the logic posed... People who tow like trucks that pull best from 40-70 so they can get into traffic and out of it... but I digress, as it is getting off topic.
I have seen the average RPM noticed by us on the forum as between 1600-2000 rpms at 70mph...
I think that RPM range speaks towards automatic trucks, though. My manual, and Frenchy's, it seems, averages a good bit higher at 70 mph, if we're already pulling 1900-2200 RPM at 60 mph.
