Autolite 3923 spark plugs
Old Jun 28, 2007 | 11:02 AM
rick4dak's Avatar
rick4dak
Default RE: Autolite 3923 spark plugs
So here's my dumb question for the day:
Are the plugs under the valve covers ? I hadn't looked under the hood for a while until I bought new plugs and when I finally looked, couldn't see them.
Old Jun 28, 2007 | 11:55 AM
superdak05's Avatar
superdak05
no. each plug has a coil pack on top of them. unscrew the holding nut and simply pull up on the whole pack itself. plug is down in the hole.
[IMG]local://upfiles/31284/6928EC59E90C45A5AFE906E34CB2C5F3.jpg[/IMG]
[IMG]local://upfiles/31284/8B9CD8963C5E46E89AEEDA26BCC3A028.jpg[/IMG]
Old Jun 28, 2007 | 11:56 AM
luvmydak's Avatar
luvmydak
Each plug has it's own dedicated ignition coil over each plug held in place with a nut/stud.It looks like a little black box with a electrical connector with wires to anti-knock sensors. Don't look for cables or a distributor. It has neither.
Old Jun 28, 2007 | 12:42 PM
rick4dak's Avatar
rick4dak
...saw your pictures, looked under my hood, found them.
Thanks.
MonkeyWrench4000's Avatar
MonkeyWrench4000
ok so what im getting from all this is, the copper plugs are cheaper, and they provides the smoothest idle.
BUT, the ones that Jimbo put in, the platinum tip ones, will they last longer? Thats what Im interested in, I thought you could run a platinum plug for 100k without a problem.
Dont the copper plugs sh*t the bed pretty quick or am I wrong?
Old Jun 28, 2007 | 12:45 PM
Frenchy's Avatar
Frenchy
from what ive heard the plats last longer, sure... but they also cause rough idle and misfire... or somethng like that
