HEMI?
Old Jul 18, 2007 | 07:07 AM
curtiplas's Avatar
curtiplas
Default HEMI?
Hey guys I know we've briefly discussed this before but what size hemi fits in our engine compartment... just out of curiousity...
Old Jul 18, 2007 | 08:00 AM
Dak_in_Black's Avatar
Dak_in_Black
Default RE: HEMI?
Over on the dakota durango forum someone with a 2000 Dak put in a 5.7 Hemi. Just do a search for 'engine swap'.
Don't know if that helps....
Old Jul 18, 2007 | 08:47 AM
Altair's Avatar
Altair
Dak attack!
Default RE: HEMI?
ORIGINAL: curtiplas
Anything will fit depending how much work you want to do. I would think you could cram the 5.7 in there without moving the firewall but maybe not.
Old Jul 18, 2007 | 09:13 AM
Dak_in_Black
Default RE: HEMI?
ORIGINAL: Altair
IIRC the motor mounts had to be fabbed and the oil pan becasue he had a 4x4. Everything else was "simple" wiring harnesses, pcm flash (?), torque convertor, etc...
Old Jul 18, 2007 | 09:56 AM
curtiplas's Avatar
curtiplas
Default RE: HEMI?
Okay... lets assume I want to get the most amount of power for the least amount of work. so I'm looking at the small 5.7L hemis or a 426 ... but I noticed that the 426 and one of the 5.7L's is carborated... and IDK what that means... also if I do EVENTUALLY do an engine swap besides the engine and manifolds or headers what else would I have to swap in order to get everything right?
Old Jul 18, 2007 | 10:27 AM
superdak05's Avatar
superdak05
Default RE: HEMI?
go to my other web site www.dodgetruckworld.com and go to the dakota sections there is a guy that has done this swapped and has pics and videos of the monster
Old Jul 18, 2007 | 12:40 PM
DakotaStone's Avatar
DakotaStone
Default RE: HEMI?
I know that there was a guy that put a 6.1L in his dak. It was a 2005, but they were having a problem with the ECU.
You would probably have to change the tranny along with a few mounts. There's a company in Spokane, WA, that has a 5.7 witht he tranny and the ecu for $5500.00. I'd buy it if I could afford it and drop it into my truck.
Carburated is an old form of mixing air and fuel. It was more of a hassle to deal with because you have to manually adjust it for different times of the year.
Old Jul 18, 2007 | 01:27 PM
OneBadKota's Avatar
OneBadKota
Default RE: HEMI?
I would think you could do the 5.7L and the new 392 and still keep it fairly stock all the way around inside.
If it were me and I had time and money. I'd throw a 528 in it with some F.I and have a fun sleeper.
Old Jul 18, 2007 | 05:27 PM
Dak_in_Black
Default RE: HEMI?
ORIGINAL: superdak05
That's the same guy from the dakota durango site.
Read through and it is a pretty good run down of what you are going to need...
