Turbo
Old Aug 8, 2007 | 12:39 PM
4x4QC06V8DKTA's Avatar
4x4QC06V8DKTA
Default RE: Turbo
if you take your 3.7L to a performance shop they should be able to re-flash your computer to fit all the demands your motor will need with putting a turbo on it. my 96 3.9L V6 was ProCharged and i took it to EB3 Performance and yeah you know they tuned it re worked the computer so it would meet the needs my truck needed on fuel and everything...yeah but it wasn't cheap, Procharger, injectors, TB and other mods...but yeah a specialty shop should be able to work with your Stock ECU and make it work!
Old Aug 8, 2007 | 03:05 PM
turbot_bird's Avatar
turbot_bird
Default RE: Turbo
I havent found a shop around here that will touch our computers
Old Aug 9, 2007 | 01:11 PM
slehner's Avatar
slehner
Default RE: Turbo
Ok, I'll try asking around some local shops for flashing the ECU. I'm just wondering how it was done because between what jet told me and how a guy I work with it sounded like I would need adifferent ECU. Jet made a comment about the map sensor and reading a negative vacumme. The guy I work with is familiar with turbo'd Hondas but he can only really guess at dodge setups but I'll ask around at he local shops too.
Thanks
Old Aug 9, 2007 | 01:14 PM
slehner's Avatar
slehner
Default RE: Turbo
Oh you know that computer that the dealer has that plugs into these vehicals? Is that capable of flashing the engine settings?
Old Aug 13, 2007 | 12:43 AM
slehner's Avatar
slehner
Default RE: Turbo
Bump...
