Lambo Door Kit
Old Aug 9, 2007 | 12:16 PM
Dak_in_Black's Avatar
Dak_in_Black
Default Lambo Door Kit
Still bored....
It is for a Mitsu Raider, but is should work, no??
http://cgi.ebay.com/ebaymotors/Mitsu...spagenameZWDVW
Old Aug 9, 2007 | 01:21 PM
Cuban11182's Avatar
Cuban11182
Default RE: Lambo Door Kit
it should work
Old Aug 9, 2007 | 02:14 PM
Dak_in_Black
ORIGINAL: Cuban11182
it should work
Not my "thing" but someone here may like it....
Old Aug 9, 2007 | 06:39 PM
texasbluedak's Avatar
texasbluedak
yeah, it says in the Q&A portion that it will fit any U.S. car or truck. When you are the winning bidder you tell them the year,make, and model and they send you the right brackets. Definately not my thing either, but I will say its pretty cheap,even though you have to do all the work. There is a guy here in S.A. that has is own shop, but he charges $650. Come on Dak, you don't want lambo doors to go with your new bed topper ???
Old Aug 9, 2007 | 09:45 PM
JAB02LHS's Avatar
JAB02LHS
The local Dodge dealer had Lame-bos on a Charger R/T. The were installed by one of the high end custom shops.
The hinge is attached to the sheet metalframe between the inside and outside door panels. It seemed to have a backing plate on the inside but the tin around the mounting plates was flexing a lot.I can see a lot of alignment problems as the metal stresses.
