Thanks Graythang, Power wire mod
K, I'll get a Molex order going of say 15 connectors. Remember the wire leads will need to be crimped on the insert pins. I have the crimp tool at work but it’s not mine. You can more than likely crimp the pin crimp with a small pair of needle nose. The other thing I can do is crimp the leads on before I send them out. I will find out the price with pins on Wednesday. We have an Atlas launch Monday and Tuesday is full of post launch stuff so Wednesday will be the day I can get this going.
Search for it, it's been talked about FOREVER, from installation, to what it does, everything...
Just click the search button, type in power wire then change the section to search in, to the 3rd Generation Dakota....
You'd be surprised with what you find!
Guest
Posts: n/a
https://dodgeforum.com/searchpro.asp...p;timefilter=0
There, now all you have to do is click... that is the search for "power wire"
If you scroll to the bottom of the page, there is a quick search function where you can type in the search term and select the area of choice....
also keep an eye on the related threads section too...
