rear block & u-bolt
Old Sep 13, 2007 | 11:01 PM
Mori31's Avatar
Mori31
Default rear block & u-bolt
hi im new on this site and i am not verry good in english write sorry about that (im frenchy guy)
i have buy trail master leveling kit for the front of my dakota 2006 and i want lift the rear of my truck whit 1.5" block
my question was all block fit on? this is standard?i search on the net for a kit for my dakota and i find nothing ??? i find many lowering kit...
can i put a kit of dodge ram 1500 ?? this is the same size?what is the correct size for u-bolt? 3.5" wide or 3 5/8" thread 9/16"?
im really newbe... what kind of stuff i need to lift my rear truck ?? block u-bolt size? and need new center bolt for my leaf? pin size on block 9/16" ? hole size?
your site was verry good i have read many subject excellent!!!
i hope you can hunderstand my bad write english
Old Sep 13, 2007 | 11:55 PM
vandutton's Avatar
vandutton
Default RE: rear block & u-bolt
Most local auto stores carry lift blocks. You can grab them there. They are pretty much universal. Ifthey don't have them, go to autozone.com and grab them there.
Old Sep 14, 2007 | 01:01 AM
Altair's Avatar
Altair
Dak attack!
Most people have been buying the universal's from Autozone. Frenchy needs to post in this thread, lol.
Old Sep 14, 2007 | 01:31 AM
Frenchy's Avatar
Frenchy
Hahaaha
Werd up...
There, I posted.
Old Sep 16, 2007 | 11:18 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Yes, the kit is standard, or universal. You can buy any block lifting kit. I bought mine at autozone. I also have the TM leveling kit, and blocks in the rear. I went with 2" blocks. All you need is the blocks, and the longer u-bolts, and they will fit perfectly. No need to have the blocks angled, they will work fine right off the store shelf.
Make sure you get aluminum blocks. Although they have a lower crush strength, they handle vibration, heat and cold, and the elements much better then the cast iron blocks.
