Ethanol and MPG
Old Sep 25, 2007 | 12:44 AM
Growlor's Avatar
Growlor
Default Ethanol and MPG
Hi all,
I am a 2nd time Dakota owner (well leaser at least) and traded-in my 2005 Dakota 4WD quad 3.7 and got a 2007 Dakota 4WD quad 4.7 flex about a month ago (technically, I swapped the 05 Dakota out for my wife's 07 PT convertible and drove her 05 Durango for a month then swapped the 05 Durango for the 07 Dakota, but that is more detail than most of you probably care about )
Since I got the flex fuel, it has been running entirely on e85 . The only "real gas" I ever put in it was about 1/2 tank to get me from the town the dealer was in to the gas station near home that sold e85 and still have more than 1/4 tank as Dodge recommends when switching fuels. So far, performance has been fine, but going from the 3.7 to the 4.7 I don't really have a good camparison. I just know that when I ask it to go fast, it is quite happy to comply.
Now, before I scare you all with my mileage, let me set the stage by saying that with my 05 4WD quad and a 3.7 I got about 13+MPG with the unleaded gas being retailed in our area. That should give you a rough baseline of my driving style, the effect of speed bumps on my street and lots of stop and go driving (my poor trucks never get a chance to warm-up as it takes less than 10 minutes from my house to the parking lot at work.)
My current mileage in the 07 4WD quad cab 4.7 flex is hovering around 9.8-10.2 mpg with e85. I was curious if anyone else was running e85 on a regular basis and if they had any pointers on things to do to bump the mpg up. I like the idea I saw about changing-out the plugs, but honestly, I can't even find the darn things on modern engines anymore (they seem to hide them under plastic covers or something like that), but I did kind of get lazy since my first new "car" was an 89 Wrangler with the 2.5 that nearly had enough room to climb into the hood with the engine anytime you needed to work on it.
Growlor
Old Sep 25, 2007 | 01:07 AM
Altair's Avatar
Altair
Dak attack!
Default RE: Ethanol and MPG
Well I don't know from experience but from what I've read most flex fuel engines get lower mpg with ethanol than with gas. The spark plugs aren't too hidden on these, they just look a little different. When you're looking at the engine you'll notice there's no distributor, these trucks use coil packs right on the plugs. There's detailed information on removal and just about everything else in the service manual. There's a link in the sticky's at the top of the forum to download it, very useful to have.
Welcome to DF!
Old Sep 25, 2007 | 07:07 AM
HankL's Avatar
HankL
My parent have had a flex fuel version of the 3.3V6 Dodge minivan since 2001 and it has about the same percentage decrease in MPG on E85 as you describe for your Dakota. I recently drove it from S Florida to Arkansas and the one tank of E85 I tried got about 30% worse MPG than the tanks before and after of 87 octane gasoline.
Here's an old post about what Consumer Reports magazine found .
Consumer's Reports did some testing on a Chevy Tahoe and found this:
This chart shows how our 2007 Chevrolet Tahoe performed while running on E85
and gasoline in three fuel-economy tests and overall, in four acceleration
tests, and in three emissions tests for gasoline vehicles.
E85 GASOLINE*
Fuel economy, mpg
City 7 9
Highway 15 21
150-mile trip 13 18
Overall 10 14
Acceleration
0-30 mph, sec. 3.4 3.5
0-60 mph, sec. 8.9 9.1
45-65 mph, sec. 5.7 5.8
Quarter-mile, sec./mph 16.8/84.6 16.9/84.5
Emissions, parts per million
Nitrogen oxide 1 9
Hydrocarbons 1 1
Carbon monoxide 0 0
*Blended with 10 percent ethanol.
{It is interesting to note how much E85 decreases NOx pollution and using some E85 as a trick to get older vehicles to pass emissions tests that failed NOx does seem viable.}
CONSUMER REPORTS TESTS SHOW THAT E85 ETHANOL OFFERS CLEANER EMISSIONS-BUT
POORER FUEL ECONOMY
E85 fuel is unlikely to fill more than a small percentage of U.S. energy needs
October 2006 issue cover
October 2006 Issue
YONKERS, NY - Tests and an investigation by Consumer Reports conclude that E85
ethanol will cost consumers more money than gasoline and that there are
concerns about whether the government's support of flexible fuel vehicles is
really helping the U.S. achieve energy independence.
Findings from CR's special report include:
* E85, which is 85 percent ethanol, emits less smog-producing pollutants
than gasoline, but provides fewer miles per gallon, costs more, and is hard to
find outside the Midwest.
* Government support for flexible-fuel vehicles, which can run on either
E85 or gasoline, is indirectly causing more gasoline consumption rather than
less.
* Blended with gasoline, ethanol has the potential to fill a significant
minority of future U.S. transportation fuel needs.
To see how E85 ethanol stacks up against gasoline, Consumer Reports put one of
its test vehicles, a 2007 Chevrolet Tahoe Flexible-Fuel Vehicle (FFV) through
an array of fuel economy, acceleration, and emissions tests.
Overall fuel economy on the Tahoe dropped from an already low 14 mpg overall
to 10. In highway driving, gas mileage decreased from 21 to 15 mpg; in city
driving, it dropped from 9 mpg to 7. You could expect a similar decrease in
gas mileage in any current flex fuel vehicle because ethanol has a lower
energy content than gasoline-75,670 British thermal units (BTUs) per gallon
instead of 115,400 for gasoline, according to the National Highway Traffic
Safety Administration. As a result, you have to burn more fuel to generate the
same amount of energy.
With the retail pump price of E85 averaging $2.91 per gallon in August,
according to the Oil Price Information Service, a 27 percent fuel-economy
penalty means drivers would have paid an average of $3.99 for the energy
equivalent of a gallon of gasoline.
When Consumer Reports calculated the Tahoe's driving range, it found that it
decreased to about 300 miles on a full tank of E85 compared with about 440 on
gasoline. So, motorists using E85 would have to fill up more often.
Most drivers in the country have no access to E85, even if they want it,
because it is primarily sold in the upper Midwest; most of the ethanol in the
U.S. is made from corn, and that's where the cornfields and ethanol production
facilities are located. There are only about 800 gas stations-out of 176,000
nationwide-that sell E85 to the public.
When Consumer Reports took its Tahoe to a state-certified emissions-test
facility in Connecticut and had a standard emissions test performed, it found
a significant decrease in smog-forming oxides of nitrogen when using E85.
Despite the scarcity of E85, the Big Three domestic auto manufacturers have
built more than 5 million FFVs since the late '90s, and that number will
increase by about 1 million this year.
A strong motivation for that is that the government credits FFVs that burn E85
with about two-thirds more fuel economy than they actually get using gasoline,
even though the vast majority may never run on E85. This allows automakers to
build more large, gas-guzzling vehicles than they otherwise could under
Corporate Average Fuel Economy rules. As a result, these credits have
increased annual U.S. gasoline consumption by about 1 percent, or 1.2 billion
gallons, according to a 2005 study by the Union for Concerned Scientists.
From an alternative-energy perspective, it doesn't matter whether ethanol is
blended as E85 or in lower mixes such as E10 (a 10/90 ethanol/gasoline
mixture) that all cars can burn; a given amount of ethanol still goes just as
far in reducing demand for gasoline. Experts agree that the maximum amount of
ethanol you can get from corn in the U.S. is about 15 billion gallons. But
scientists are working on producing ethanol from other plant material, called
cellulose, which could increase this capacity by as much as 45 billion
gallons. (For comparison's sake, the U.S. burned 140 billion gallons of
gasoline in 2005.)
The important backdrop to the ethanol debate, of course, is that petroleum is
a finite resource that's rapidly being depleted. Government scientists are
planning for a day when world oil production peaks and begins to slow. They
say the country must begin planning for alternatives 20 years before that
peak. Today ethanol is receiving their attention because it requires fewer
technological breakthroughs and less infrastructure development than batteries
or fuel cells, and by including cellulose, its capacity can exceed that of
biodiesel.
HankL's note:
I am totally convinced ethanol is a 'precious resource' that the USA can use to improve both MPG and power. See this post:
https://dodgeforum.com/m_746747/tm.htm
for the way it should be done.
The present practice of making ethanol and either blending 10% of it into gasoline or making E85 is a tremendously wasteful 'boondoggle' created by Archers-Daniel-Midland company, Cargill company, Senator Bob Dole and Sen Chuck Grassley.
