trans and axle capacities???
Old Oct 19, 2007 | 11:46 PM
IROOST1's Avatar
IROOST1
Default trans and axle capacities???
I am looking to change my axle fluid and know the types of oil, just not the capacities.
Also, looking for the trans oil capacity.
And is the transfer case a seperateitem to change(my first 4x4), what is its capacity?????????????????????????????????????????? ????????????
Old Oct 20, 2007 | 07:46 AM
Dak_in_Black's Avatar
Dak_in_Black
Default RE: trans and axle capacities???
ORIGINAL: IROOST1
Front Differential is 3.6 pints and a PITA to change/replace....
Rear Differential is 4.4 pints
Transfer Case depends on which one you have. The AWD is 2.7 pints, the other is 2.3 pints
Transmission, if all you are doing is dropping the pan then it is 6.6 quarts, if you intend on pumping it all out then it is 14 quarts
