Tire Size?
Old Oct 31, 2007 | 06:38 PM
kingsaffey's Avatar
kingsaffey
Default Tire Size?
285/50/20 or 275/45/20
Old Oct 31, 2007 | 07:26 PM
Frenchy's Avatar
Frenchy
Default RE: Tire Size?
wtf?
are you asking which will fit?
If so, I know the 275/45/20 will fit, no rubbing...
The other, I'm assuming there will be rubbing, they're wider, and taller...
Old Oct 31, 2007 | 08:33 PM
kingsaffey's Avatar
kingsaffey
yes, which would vbe the better size?
Old Oct 31, 2007 | 09:16 PM
importkiller76's Avatar
importkiller76
First of all, i'm fairly certain that the bigger ones probably won't fit. Second I would say that it depends on what kind of look you are going for. Are these mud tires? Are they low-profiles on some big a$$ rims? Need more info to know how to answer lol
Old Oct 31, 2007 | 09:38 PM
kingsaffey's Avatar
kingsaffey
20" SRT wheels, want some all season perfomance tires
Old Oct 31, 2007 | 10:39 PM
Frenchy's Avatar
Frenchy
good luck w/ all season and 20s...
Old Nov 1, 2007 | 05:26 PM
kingsaffey's Avatar
kingsaffey
just want to know if 285/50/20 will rub
Old Nov 1, 2007 | 08:58 PM
QCDAKblue's Avatar
QCDAKblue
I know the 275/40/20 will fit fine, also there are a tome of all season tires avaiale. Falkin tires are avaiable ( Do not suggestthem as the cupped in less than 10K on mine). I may choose the GY eagle GT2s (they are good price). I like the michlin 4x4 but come with a steep price.
Old Nov 1, 2007 | 09:15 PM
LB's Avatar
LB
285/50/20 will rub even with 2" level kit, but a little trimming of the inside edge of the mudflap will take care of it. This was on Dodge RAM 20" rims, different offset may produce different results.
HTH,
LB
Old Nov 2, 2007 | 12:17 PM
scottscan's Avatar
scottscan
this is a 275/45/20 if i had it to do over i would have gotten 265/50/20 so it would have been a little taller.
