Installing autolite 3923 plugs
Old Nov 13, 2007 | 10:28 AM
superdak05's Avatar
superdak05
Default RE: Installing autolite 3923 plugs
the 3922 plugs are a little cooler than the 3923. the 3922 are for nitrous applications. that way the motor dont go boom. i am happy with my 3923 plugs.
Old Nov 13, 2007 | 10:40 AM
SinCity R/T's Avatar
SinCity R/T
As mentioned above...
The standard plug for the 3.9L V6, 4.7L V8, 5.2L V8, 5.9L V8, etc. is the 5224. A lot of people have switched to the 3923 which is a little bit shorter than the 5224 plug, and one heat range colder. The Magnum V6/V8 tends to detonate when hot or under heavy load - the reason people started switching to the 3923 wasto give a more controlled burn by preventing early detonation. Cooler plugs do NOT make more power! If you're feeling "more power" from a 3923, it's because your prevous plugswere probablyFUBAR, or your engine was experiencing a lot of detonation issues (you should also look into replacing your cap/rotor, spark plug wires, use higher octane fuel, etc.)
Standard plug length: 5224
One heat range colder: 5223
Two heat ranges colder: 5222
Shorter length: 3924
One heat range colder: 3923
Two heat ranges colder: 3922
Old Nov 13, 2007 | 10:52 AM
QCDAKblue's Avatar
QCDAKblue
Whatmiliage are you all changing these at? I have 06 with 18,550 on it. Non-HO. Do these have to be bought online or are they a normal part carries at the auto parts store?
Old Nov 13, 2007 | 11:00 AM
SinCity R/T
ORIGINAL: QCDAKblue
The 5224's should be standard fare at most auto shops. I've found the 3923 to be hit or miss, although my local Wally World Superstore started carrying them on a regular basis. I usually end up replacing my plugs every 5k-10k miles, but I that mileage is usually spread out over a year or longer, and I have taken my trucks to the dragstrip/autocross/etc. so they experience some hard driving.
