EBC brakes
Old Nov 14, 2007 | 06:35 PM
kingsaffey's Avatar
kingsaffey
Default EBC brakes
just got ebc rotors and pads. what is the deal with the rotor all coated with black? some protected coating?
Old Nov 14, 2007 | 07:51 PM
scottscan's Avatar
scottscan
Default RE: EBC brakes
yea, it's a protective coating . it will come off in a few miles, mine did. what pads did you get ?
see
Old Nov 14, 2007 | 09:04 PM
kingsaffey's Avatar
kingsaffey
the same as what you got, the dimpled/ slotted rotors with the green stuff pads.. how is the performance off the braking with these brakes?
Old Nov 14, 2007 | 09:07 PM
kingsaffey's Avatar
kingsaffey
did u get new calipers?
Old Nov 15, 2007 | 08:45 AM
scottscan's Avatar
scottscan
no , calipers are just painted black. and yes , the ebc rotors and pads give way more braking performance over stock . on mine when i put on brakes as they heat up they grab more i find myself lifting off the pedal some so i want stop to short. and it does all this with all most no brake dust .
Old Nov 15, 2007 | 11:56 AM
mightypizu's Avatar
mightypizu
Hi,
I've read that the EBC rotors/pads make much more noise/squeaks, is this true? Is it noticeable? Also, do you think it helped the infamous "shimmy" when braking? I'm thinking about upgrading. Thanks.
Old Nov 15, 2007 | 02:24 PM
kingsaffey's Avatar
kingsaffey
yea, well all new brakes makes noises. but they stop once they are broken in.
Old Nov 15, 2007 | 03:04 PM
studlyblueiz's Avatar
studlyblueiz
Didn't have any noises on my brakes when I first bought my truck...only showed 3 miles on the odometer. Hmm
Kinda funny though, factory brakes don't usually have that problem. I put some slotted discson an eclipse and they squeeked for awhile too
Old Nov 15, 2007 | 06:37 PM
scottscan's Avatar
scottscan
hey mightpizu , my EBC pads and rotors do not squeek what so ever . the only noise they do make is when your slowing down they have a slight tire roar noise , they say it's the grooves that cause it . but not really noticeable. i do think this helped with the shimmy problem. mine only happened in the hot summer and i think it was the rear drums with the new rotors haveing better stoping power i think it took some heat off the rear drums .....
Old Apr 17, 2008 | 01:08 PM
rick4dak's Avatar
rick4dak
Now that you guys have had your EBC brakes for 6-7 months, what do you think of them ? Any problems ? What did you do for your rear brakes when you switched fronts ?
