5W-20????
Old Nov 23, 2007 | 08:42 PM
Growlor's Avatar
Growlor
Default 5W-20????
All,
I had my first oil change in the new '07 4.7Flex 4x4QC Dak today (about 3000ish miles) and the girl at the oil shop asked if I wanted 5W-20? At first I looked at her like she was crazy and she said that was what was recommended then showed me the oil cap and sure enough, it read 5W-20.
I have never heard of this grade before. Being a native Californian (now transplanted to NW Ohio) and growing-up in the 70's-80's we either used 30wt (big V8 Fords) or 10W50 (little foreign 4 cylinders in the CA heat.)
If I remember correctly, the 5 of the 5W-20 part manes its rated for relatively cold weather (which is good seeing as how it gets REALLY cold here in the winter - cold enough my '05 3.7 used to make a nasty shriek on starting-up in the coldest of days that guaranteed bad news for engine life), but the -20 means its not rated for really high temp/is a thinner oil. My guess is that Chrysler is assuming the engines won't get that hot and using thinner oil will boost MPG. Is this the case?
Growlor
Old Nov 24, 2007 | 10:13 AM
pro4x4's Avatar
pro4x4
Default RE: 5W-20????
Wow thats odd. I use 5w-30 oil all year round. I live in Pa so it gets hot in summer and cold in winter and never had problems using 5w-30. Maybe because your engine is a flex fuel model that might be why the 5w-20.
Old Nov 24, 2007 | 10:30 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Where at in NW Ohio? Im down here in Lima, but I just got back from the Toledo/Swanton area yesterday. And to answer your question, I would just use whatever is recommended, my 3.7 says 5w-30, so like pro said, it may be different for the flex fuel vehicles.
Old Nov 24, 2007 | 11:08 AM
JimmyDiablo's Avatar
JimmyDiablo
The Hemi's with mds require 5-20. when I had my 06 Hemi I stuck to it as a lot of info and threads sd that MDS would not work properly if I did not. I made it a point to use mobile-1 5-20 especially in the Arizona heat I went through a rough summer with a lot of rough driving on and off road and it worked fine. Imo stick with the good synthetic and a good filter and you will be fine. The wierd thing is the oil damn near looks like water in consistancy
Old Nov 24, 2007 | 11:39 AM
Bigboywithav8's Avatar
Bigboywithav8
Well i have the 06 4.7L and mine ask for 5-20w on the cap 2 but i use 10-30w syntetic and i have not notice any difference
Old Nov 24, 2007 | 02:26 PM
Frenchy's Avatar
Frenchy
Hey, diesel boy.
GET OUTTA HERE!
Hahaha, I'm kidding.
My Dad's Hemi w/out MDS also calls for 5W-20.
I think it's just whatever cap they feel like putting on it, by the looks of things.
Haha
Old Nov 24, 2007 | 07:16 PM
turbot_bird's Avatar
turbot_bird
mine says 5w-30 moms 04 hemi does too. it might be for regions
Old Nov 24, 2007 | 07:48 PM
Jr. Mechanic
Yeah, +1 for regions. My dads ram down in Ft. Lauderdale calls for 10w-40.
Old Nov 25, 2007 | 11:08 AM
02wrangler's Avatar
02wrangler
I'm up here in Alaska and the dealership puts in 5w-20, and believe me it gets cold
Old Nov 25, 2007 | 04:05 PM
lowcountrykid's Avatar
lowcountrykid
yeah mine says to put 5w-20 and thats what i put in my ranger cuz it calls for it too and im down in SC where it gets hotter than ***** during the summer time and kinda cold in the winter
