Trail Master level kit questions
Old Nov 23, 2007 | 09:55 PM
kzguns's Avatar
kzguns
Default Trail Master level kit questions
Can some one who has this kit get me the dimentions of the spacers. I have a lathe and some crap metal so i was going to make them up myself. They appear to be about 1" thick but not sure also if you have the diameter of them as well as the hole size in the middle, but the thickness is the most important the rest i can measure the strut for.
Thanks for any help,
Ken
Old Nov 25, 2007 | 05:28 PM
kzguns's Avatar
kzguns
Default RE: Trail Master level kit questions
Not even a close guess?
Old Nov 25, 2007 | 05:37 PM
02wrangler's Avatar
02wrangler
When my TM kit came in, I measured the spacers at 7/8 of an inch thick. I checked them both because I was trying to figure out how it would all equal out to a 2" lift. When all said and done, installed it was close to 2" higher. Not sure if that helps, and I don't know about the rest of the measurements besides the thickness.
Old Nov 25, 2007 | 06:30 PM
AdidasCJ's Avatar
AdidasCJ
i would help you out but there on my truck and i never measured them before i put them in
Old Nov 25, 2007 | 09:54 PM
kzguns's Avatar
kzguns
Thanks that is exactly what i needed the rest of the measurments i can get off the truck. I knew that it was around an inch but i wasnt sure. Again thanks
