Truck is still Stalling!!!
Old Dec 11, 2007 | 08:12 PM
pack154's Avatar
pack154
Default Truck is still Stalling!!!
I had the TB cleaned and changed out the plugs two months ago. I pulled up to a stop sign today and the truck stalled!!!I was very suprised!
I installed the jet chip stage II two weeks ago. Maybe that has something to do with it?
Old Dec 11, 2007 | 09:27 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Truck is still Stalling!!!
https://dodgeforum.com/m_984951/tm.htm
Old Dec 11, 2007 | 09:56 PM
pack154's Avatar
pack154
Maybe it might be the EGR valve causing the stalling?
Old Dec 11, 2007 | 11:01 PM
kingsaffey's Avatar
kingsaffey
take it to dodge, ifu still have a warranty
Old Dec 11, 2007 | 11:05 PM
Destructicon's Avatar
Destructicon
with the Jet... make sure its properly seated and cliped into place. Because I live in dusty AZ, I got a small can of computer aerosol **** and blew out the chip and the module insert area before clipping into place. Have not had one problem that I can point to that could be module related.
Old Dec 12, 2007 | 11:42 AM
kzguns's Avatar
kzguns
It's the egr my truck was do that and no engine light took to the dealer and ofcourse it's fine nothing wrong they tell me, well i'm out of warranty now and the engine light comes on for the egr valve. i replaced the egr valve ($70) and all is good.
Old Dec 12, 2007 | 11:50 AM
pack154's Avatar
pack154
My truck is out of warrantyas well. It hasn't stalled on me today, yet. I might try cleaning the EGR first and see if that helps.
I think ifANY vehicle stalls, the check engince light should comes on throw a code. That way one could tell what the heck is going on with it and fix it.
Old Dec 12, 2007 | 01:17 PM
kzguns's Avatar
kzguns
you would have to remove it to clean it and if your going to do that you might aswell spend the 70 bucks and replace it. mine looked fine it wasn't carboned up or anything. there is a diaphram in there and if it is compromised in any way it will not work right and eventualy fail then throw a code.
Old Dec 12, 2007 | 01:39 PM
RMUDBUGS's Avatar
RMUDBUGS
My truck stalls about once a month. I had the dealer reprogram my ECU with the latest program and it has not stalled in the last 2 months. I sure hope it's fixed.
Old Dec 12, 2007 | 01:49 PM
pack154's Avatar
pack154
The dealship (3 months ago when I first brought it in) wouldn't re-flash the ECM for me because the check engine light didn't come on. They stated that it had nothing to do with reprograming the ECM. If it stalls again (which I'm sure it will) I guess I'll have to knock some heads around at the service dept.
