What the h*** is this?!
Old Jan 11, 2008 | 11:37 AM
  #22
Destructicon's Avatar
Destructicon
Default RE: What the h*** is this?!
http://www.turbochargedpower.com/Common%20Terms.htm
"Usually measured in pounds per square inch....Boost is also measured in Bar. One Bar equals 14.7 psi."
Which I do know 14.7 psi is atmospheric pressure... but I dont know if there is a mathmatical/scientific way to break it down to 1lb of boost = x amount of RPMs. Given the fact that engine sizes, lrg/sm turbos, intakes, etc all play a factor in generating boost.
I did see that some cars can generate the lowest amount of boost at 500rpm where others were 2k+... I guess it just depends.
Anyboy else know that answer?
Old Jan 12, 2008 | 12:06 AM
  #23
BACKnBLACK's Avatar
BACKnBLACK
And to answer the first question of this thread, that is the result of what happens when a truck takes ill-advised "performance enhancing ram air". It gets all bulked up like Bonds or Clemens and then breaks down eventually.
