Code Question
Old Jan 11, 2008 | 11:03 AM
Dak_in_Black's Avatar
Dak_in_Black
Default Code Question
Got the truck back from the Body Shop and the CEL was on...they said they had no way to read the code...
I took it over to Advance and the code reads P0113 IAT Sensor 1 Circuit High Input
Is this something I should be concered about? I reckon they did not put the K&N back on correctly and the sensor is not all the way in the tube...
Comments / recommendations?
Old Jan 11, 2008 | 11:14 AM
superdak05's Avatar
superdak05
Default RE: Code Question
i had that sensor code. check to see if the connection are tight between the wiring harness and the sensor. also check to see if one of the wires broke free from the factory harness. you will not get a code if it is not put back. only if the sensor went bad or if the wiring harness is not connected
Old Jan 11, 2008 | 08:23 PM
Dak_in_Black
Thanks for the info...
I decided to call Geico and they told me to take the truck back and have them fix it (which is what I should have done the first time)...so back to the shop on Tuesday!!
They are going to take it to the dealer to look at and fix...
Old Jan 12, 2008 | 04:17 AM
Mahadigus's Avatar
Mahadigus
that code comes up everytime you start a dodge vehicle with air temp sensor unlugged. just make sure its plugged in and then clear the code and your golden.
