indash dvd
Guest
Posts: n/a
you just need to make sure you use good solid components and find a way to keep it from vibrating too much...
All that said, I may not do it simply because I may try to find a cheap 2002+ neon...
Then there may be a plan in the works for an SRT swap. so I have to save up where I can. lol
WHY do the swap? why not just buy one? i mean its not a bad plan...i mean find an 03 and you can buy it for 6-7grand and then buy the motor, trans, turbo, wiring, mounts, axles and all that will run you another 5-7 grand...just for the block is 3grand...so you might end up spending close to 8-9grand for everything to get it put in the car and then to get it tuned right and wat else not another 1,000 bucks atleast...so i mean in the end you end up with the same amount into it as buying one would cost...though insurance may not be as high for a NON SRT CAR as they would see it as, but up to you bud!
Guest
Posts: n/a
yeah... 03 sxt in the paper for 4500...
And I found a place in PA that will DO the swap for 5 grand... thats motor, trans, everything...
Where can I find an SRT-4 for under 10?
With the bonus of cheaper insurance and the sleeper effect?
