trans fluid & filter change on 4X4
Old Feb 16, 2008 | 02:23 PM
LB's Avatar
LB
Default trans fluid & filter change on 4X4
Has anyone done this on an '05 up4X4 here?
Do I need to remove the crossmember or will the trans pan clear it?
Also finally going to install the Transgo at the same time, willthe valve body clear the crossmember?
Any thoughts or tips are appreciated.
Thanks,
LB
Old Feb 17, 2008 | 09:32 PM
turbot_bird's Avatar
turbot_bird
Default RE: trans fluid & filter change on 4X4
I had to drop my crossmember to get the pan and valvebody out on my 4x2 so I imagine you will have to also
Old Feb 17, 2008 | 10:41 PM
LB's Avatar
LB
Thanks for the reply, It looks tight but I was hopeful I might be able to avoid it.
You mentoined valvebody, did you do a shift kit?
LB
Old Feb 18, 2008 | 01:00 AM
turbot_bird
ya, transgo
