Limited Slip Differential
Old Feb 21, 2008 | 03:55 PM
Ryan2008's Avatar
Ryan2008
Default Limited Slip Differential
Does anyone know what type of limited slip differential is in a 2006 Dakota 2WD with the TRX package?
Old Feb 21, 2008 | 06:23 PM
superdak05's Avatar
superdak05
Default RE: Limited Slip Differential
open up your glove box and at the back of it there should be a sticker telling you this info. if it is not there then you can goto www.allpar.com and type in your vin number and it will give you the info also
Old Feb 22, 2008 | 06:56 AM
Ryan2008's Avatar
Ryan2008
I do not own a Dakota yet, are there different types of limited slip differentials available for the 2006 2wd model?
Old Feb 22, 2008 | 09:29 AM
Hunterdude's Avatar
Hunterdude
Its a fairly mediocre clutch type LSD.
Old Feb 22, 2008 | 09:55 AM
rookie's Avatar
rookie
mine is a 9" corporate 3.55 LSD, if i remember correctly. There are 8.25", full slip, and 3.92, but iknow not what combinations are available. You cannot get a 3.92 : 1 rear or a HO engine w/ a manual.
