newbee more questions
Old Mar 5, 2008 | 07:03 AM
tfowler306's Avatar
tfowler306
Default newbee more questions
I picked up my new new to my Dakota last night, I am so excited. I now have a truck that I want to keep driving instead hurry and get there so I can get out of it...
The check engine light came on on my way to work this morning, It was on when I test drove it and I asked about it. The dealrship told me it was because the gas cap wasent on correctly. They filled up the tank last night before I took it so I was wondering if it was a gas cap so I took it off and put it back on. If thats it with the light go off by itself?
also where is the plug for the scan tool to check the cods?
Old Mar 5, 2008 | 11:32 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Default RE: newbee more questions
Yeah the gas cap is possibly throwing the MIL light. From my understanding, as long as you correctedthe gas cap and thenthreegood trips of the monitoring system, the light should go out. The plug for the scan tool is to the right of your hood release. I pasted a section from the repair manual that explains the MIL and how it works an such.
MIL Illumination
The PCM Task Manager carries out the illumination of the MIL. The Task Manager triggers MIL illumination upon
test failure, depending on monitor failure criteria.
The Task Manager Screen shows both a Requested MIL state and an Actual MIL state. When the MIL is illuminated
upon completion of a test for a third trip, the Requested MIL state changes to OFF. However, the MIL remains
illuminated until the next key cycle. (On some vehicles, the MIL will actually turn OFF during the third key cycle)
During the key cycle for the third good trip, the Requested MIL state is OFF, while the Actual MILL state is ON. After
the next key cycle, the MIL is not illuminated and both MIL states read OFF.
Diagnostic Trouble Codes (DTCs)
With OBD II, different DTC faults have different priorities according to regulations. As a result, the priorities determine
MIL illumination and DTC erasure. DTCs are entered according to individual priority. DTCs with a higher priority
overwrite lower priority DTCs.
Priorities
²
Priority 0 —Non-emissions related trouble codes
²
Priority 1 — One trip failure of a two trip fault for non-fuel system and non-misfire.
²
Priority 2 — One trip failure of a two trip fault for fuel system (rich/lean) or misfire.
²
Priority 3 — Two trip failure for a non-fuel system and non-misfire or matured one trip comprehensive component
fault.
²
Priority 4 — Two trip failure or matured fault for fuel system (rich/lean) and misfire or one trip catalyst damaging
misfire.
Non-emissions related failures have no priority. One trip failures of two trip faults have low priority. Two trip failures
or matured faults have higher priority. One and two trip failures of fuel system and misfire monitor take precedence
over non-fuel system and non-misfire failures.
DTC Self Erasure
With one trip components or systems, the MIL is illuminated upon test failure and DTCs are stored.
Two trip monitors are components requiring failure in two consecutive trips for MIL illumination. Upon failure of the
first test, the Task Manager enters a maturing code. If the component fails the test for a second time the code
matures and a DTC is set.
After three good trips the MIL is extinguished and the Task Manager automatically switches the trip counter to a
warm-up cycle counter. DTCs are automatically erased following 40 warm-up cycles if the component does not fail
again.
For misfire and fuel system monitors, the component must pass the test under a Similar Conditions Window in order
to record a good trip. A Similar Conditions Window is when engine RPM is within ±375 RPM and load is within
±10% of when the fault occurred.
NOTE: It is important to understand that a component does not have to fail under a similar window of operation
to mature. It must pass the test under a Similar Conditions Window when it failed to record a Good Trip for DTC erasure for misfire and fuel system monitors.
DTCs can be erased anytime with a DRB III. Erasing the DTC with the DRB III erases all OBD II information. The
DRB III automatically displays a warning that erasing the DTC will also erase all OBD II monitor data. This includes
all counter information for warm-up cycles, trips and Freeze Frame.
Trip Indicator
The
Trip is essential for running monitors and extinguishing the MIL. In OBD II terms, a trip is a set of vehicle
operating conditions that must be met for a specific monitor to run. All trips begin with a key cycle.
Good Trip
The Good Trip counters are as follows:
²
Specific Good Trip
²
Fuel System Good Trip
²
Misfire Good Trip
²
Alternate Good Trip (appears as a Global Good Trip on DRB III)
²
Comprehensive Components
²
Major Monitor
²
Warm-Up Cycles
Specific Good Trip
The term Good Trip has different meanings depending on the circumstances:
²
If the MIL is OFF, a trip is defined as when the Oxygen Sensor Monitor and the Catalyst Monitor have been
completed in the same drive cycle.
²
If the MIL is ON and a DTC was set by the Fuel Monitor or Misfire Monitor (both continuous monitors), the
vehicle must be operated in the Similar Condition Window for a specified amount of time.
²
If the MIL is ON and a DTC was set by a Task Manager commanded once-per-trip monitor (such as the Oxygen
Sensor Monitor, Catalyst Monitor, Purge Flow Monitor, Leak Detection Pump Monitor, EGR Monitor or
Oxygen Sensor Heater Monitor), a good trip is when the monitor is passed on the next start-up.
²
If the MIL is ON and any other emissions DTC was set (not an OBD II monitor), a good trip occurs when the
Oxygen Sensor Monitor and Catalyst Monitor have been completed, or two minutes of engine run time if the
Oxygen Sensor Monitor and Catalyst Monitor have been stopped from running.
To count a good trip (three required) and turn off the MIL, the following conditions must occur:
²
Engine in closed loop
²
Operating in Similar Conditions Window
²
Short Term multiplied by Long Term less than threshold
²
Less than threshold for a predetermined time
If all of the previous criteria are met, the PCM will count a good trip (three required) and turn off the MIL.
Misfire Good Trip
If the following conditions are met the PCM will count one good trip (three required) in order to turn off the MIL:
²
Operating in Similar Condition Window
²
1000 engine revolutions with no misfire
Warm-Up Cycles
Once the MIL has been extinguished by the Good Trip Counter, the PCM automatically switches to a Warm-Up
Cycle Counter that can be viewed on the DRB III. Warm-Up Cycles are used to erase DTCs and Freeze Frames.
Forty Warm-Up cycles must occur in order for the PCM to self-erase a DTC and Freeze Frame. A Warm-Up Cycle
is defined as follows:
²
Engine coolant temperature must start below and rise above 160° F
²
Engine coolant temperature must rise by 40° F
²
No further faults occur
Old Mar 5, 2008 | 11:43 AM
lghtngblt02
There is the links to the service manual and parts catalog, hope this helps also. I would recommend saving them to your computer.
Old Mar 6, 2008 | 05:34 AM
tfowler306's Avatar
tfowler306
thanks for the info files saved.....
Old Mar 6, 2008 | 01:09 PM
lghtngblt02
No problem
