1" Blocks VS 2" Blocks
Old Mar 9, 2008 | 02:27 PM
Jadman's Avatar
Jadman
Default 1" Blocks VS 2" Blocks
I am looking for any input I can find on these block setups. BTW thanks MonkeyWrench4000. did you try the 2" blocks?
Any info from you guys will be appreciated.
Old Mar 9, 2008 | 08:09 PM
Hunterdude's Avatar
Hunterdude
Default RE: 1" Blocks VS 2" Blocks
Go with 1.5' blocks and split the difference. Thats what I did with no problems to date.
Old Mar 9, 2008 | 08:27 PM
Jadman's Avatar
Jadman
Did you buy 1.5's? Here I only have the choice of 1, 2, or 3. No aftermarket shocks for the rears at all? GRRRRRRRRR!
Old Mar 9, 2008 | 08:41 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Hey. Im running 1" blocks. I used to run 2" blocks. I switched to 1" blocks because the stock shocks worked with the 2" blocks, but they were kinda rough. BUT, now you can buy longer rear shocks for our trucks, from Rough Country, that will work perfect with 2" blocks. They are on the roughcountry.com website, under the leveling kit for our trucks, but they are not listed for purchase by themselves, without the kit, so to get them you need to call roughcountry and order them.
I would still be running the 2" blocks if the shocks were available back when my 2" blocks were in, now I wont bother.
Old Mar 9, 2008 | 10:58 PM
rookie's Avatar
rookie
i'm running the 2" blocks. i like the way they look. I overloaded the truck though, and instead of riding on the spring stops, i thing it bent the springs a little. never noticed any roughness.
