zex kit installed and running strong
quite happy with the turnout. system is tucked nicely away from everything and all the wiring was hid. paul did a great job. bottle was mounted in the bed along with the warmer, remote opener not installed yet, and this is the control system. no need for a button to push. works of the tps. at wide open throttle the system knows to turn on as long as the arming switch is on. pretty fail safe
[IMG]local://upfiles/31284/F58130FC82954615B2150B8697FB619C.jpg[/IMG] [IMG]local://upfiles/31284/ED263A8B48694F6BACAC1CA51665FE26.jpg[/IMG] |
RE: zex kit installed and running strong
this is were we decided would be the best spot for the nozzle. all you see in the engine compartment is this nozzle some braided lines and the purge valve
[IMG]local://upfiles/31284/74982F64509F421C82621372A4B0687F.jpg[/IMG] [IMG]local://upfiles/31284/5E97022E265A4A619637119E75AC89BA.jpg[/IMG] |
we also decided to put the complete system out of engine heat by mounting it behind the k/n filter on the heat shield. you dont even see the system unless you stick your head behind the k/n and this is all you see with the hood closed from the purge valve
[IMG]local://upfiles/31284/E4840B7EE73A447598A7E43BD3F2414B.jpg[/IMG] [IMG]local://upfiles/31284/3889BCB5577E42F88A46F1C47891318C.jpg[/IMG] |
Sweet deal man! Pull alot harder now? Did you make your dyno runs yet?
Nice. Are you going up to New England Dragway this year?
stacey, i will make a few trips up to ned. but mostly i will be running at lebanon valley. closer to home. might make a tip or so down to englishtown. depending on gas prices.
it looks good. he really did a nice job> good luck with it.
Nice install, very clean.
What shot are you running? Also, what locationdid you tap into a fuel supply from? |
i am currently running a 55 shot. at 0 degree timing. until someone comes out with a programmer for 05 and up 4.7 there is no way to take timing out to go with a larger shot. also having a micro mini controller installed. that way i can determine how much nitro i want coming off the line, then gradually giving it more. if i come off the line with the full 55 shot, i will just blow the tires off of itas for the fuel hook up. there is a schrader valve already in the fuel rail. its like a valve stem for tie inflations. remove the cap and screw the braided hose right onto it.
that is by far the coolest mod IMO
nothing better than a little juice! |
