MAP wiring
Old Jul 11, 2008 | 04:03 PM
cawalke3's Avatar
cawalke3
New Member
Default MAP wiring
I am looking to do some rewiring on the MAP sensor of my Dakota (2006, 4.7L) and can't find anything on the usage of the wires. I am specifically trying to find the signal wire. The three wires are colored, from left to right, yellow w/pink, blue w/ green, and purple w/ black. Anyone know where I can find which one is which? I have a hunch it is the yellow/pink, but not sure. Thanks for the help.
Old Jul 11, 2008 | 04:12 PM
baracis's Avatar
baracis
Default RE: MAP wiring
I know someone around here has the service manual available to send to you. I'll check my e-mail...but that shouldn't be a problem to figure out for most of these guys.
*EDIT* Sent you a PM with the link to the service manual. Scroll down on the page and you should find it.
Old Jul 11, 2008 | 08:39 PM
superdak05's Avatar
superdak05
the iat sensor should always be relocated on the daks. by keeping them away from engine heat the truck will perform better i relocated mine farther down the air tube for cooler air readings
[IMG]local://upfiles/31284/526493D33C4544C9B9FE019AA6490247.jpg[/IMG]
