06 Headlights
Am I the only one that seems to be replacing a headlamp every 2-3 months? What sort of garbage is this? Anyone ever figure out what the problem is, and did you correct it? Stopped using OEM lights long ago, switched to Silverstar, still blowing them.
depends on if you're truck is under warranty or not...
but it does sound like the alternator is putting out to much juice or you have a short in the wiring to the headlights.... is the fuse the proper fuse size as well?
but if you're not mechanically inclined, all you have to do is go pick up an alternator from autozone or your local auto store, most will put them in for you, or at least tell you how.....
