Vibration
Old Sep 8, 2008 | 07:14 AM
sdsdsd's Avatar
sdsdsd
Unhappy Vibration
I took my 05 Quad in for service. The dealer replaced R/Rear emergency brake cable and rear stabilizer bar bushings. I got the truck back and now after driving aprox 5 miles when hitting the brakes the truck vibrates badly. I feel no pulsation in the brake pedal just a rear end vibration or hopping. Needles to say the dealer has it back in the shop. They did give me a loaner.
The technician who test drove it with me was very surprised. He said I didn't even pull the wheel off. I replaced the cable and the bushings, he seemed stumpped. I'm hopping for the best.
Old Sep 8, 2008 | 07:31 AM
fireman2828's Avatar
fireman2828
Don't you have to remove the wheel and drum to change an e-brake cable? At least on older dakotas you had to.
Old Sep 8, 2008 | 08:58 AM
luvmydak's Avatar
luvmydak
Check the the Recalls and TSB (technical service bulletin) link. There is a rear vibration issue that may apply in your case. I took my '05 v6 in and fixed n/c.
Old Sep 8, 2008 | 09:14 AM
sdsdsd's Avatar
sdsdsd
No the e/brake cable is now attached externally to the rear brakes
Old Sep 8, 2008 | 10:54 AM
blkmagic's Avatar
blkmagic
The link at the top of the forum page doesn't work, is there another link someplace?
Old Sep 9, 2008 | 10:37 PM
mprohr's Avatar
mprohr
Tsb 05-002-06
Old Sep 10, 2008 | 06:35 AM
sdsdsd's Avatar
sdsdsd
Smile vibration
Problem solved Dealer says they installed the E brake cable incorrectly. Sounds like BS to me. The bottom line is the problem is gone so I don't care what they did to correct it.
