Vibration issue
Old Sep 12, 2008 | 07:30 AM
stonfootball's Avatar
stonfootball
Default Vibration issue
I put on 20" rims and tires and now i'm getting a vibration from the front end. I was told i need hub rings but every where i call they say that i don't need the rings with 20" rims. what else could be causing this rattle? anything i need to do since i got bigger rims on my truck? oh i have cross drilled rotors on the front and they both have plenty of break pads...the tires were re-balanced...what do i do now?
Old Sep 15, 2008 | 02:15 PM
superdak05's Avatar
superdak05
take the rims off and look at the studs, if there are little brass washers on the studs they need to be removed. everyone else that has that vibration issue was the cause. this should fix the problem
