Newbie Question?
Hello all. Could use some advise. The situation is this, just purchased a Daystar 2" Leveling kit for my 07 Dakota 4X4 and all was going well on the install until the step where you have to raise the lower control arm as to reconnect the upper ball joint. The instructions advise to use a floor jack. Sounds simple enough except the entire truck is lifting instead of the spring/strut compressing. It's not even getting close.
This Daystar kit is the one where the spacer sits on top of the strut. From what I have read here there are opinions that this is really not the way to go either. Send it back?
I really like the truck overall but in the hills you are almost hand cuffed even on moderate terrain. Have to do something. Would appreciated any advise and thanks.
Guest
Posts: n/a
well, I would double check the jack location... these struts are not that difficult to compress... they should be pretty easy actually.
and the above the strut spacer IMO is not the way to go. Esp. w/ a 4x4... but then again, others have done it so, lets wait to see what they say.
My buddy ran into the same issue with a 2.5" Auto Spring Leveling kit. Its not installed on his dakota, so I think he gave up.
Is there a way to compress the strut spring with it installed?
these assemblys are very weak.
