Friction Additive
Old Oct 17, 2008 | 07:51 PM
dpluta's Avatar
dpluta
Default Friction Additive
Hi.
2006 Dakota Quad Cab 4x2 v6
I'm changing the rear diff fluid and someone said I need a friction additive on top of the 75/140 Mobile 1 fluid.
Thoughts?
Old Oct 17, 2008 | 08:08 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
I believe if you have a rear locker, you need an additive. If you don't have a rear locker, then you don't need the additive. Just check the owners manual, if will give you the info you need.
Old Oct 17, 2008 | 11:07 PM
Altair's Avatar
Altair
Dak attack!
The additive is needed if your truck is equipped with a limited-slip rear diff.
Old Oct 20, 2008 | 10:18 AM
tankmechus's Avatar
tankmechus
Default dpluta
You need the additive if you have the limited-slip differential like Altair said. Before you head to the dealership and dish out about $7.50/ bottle, I have 2 bottles that I'm trying to get rid of. I used to have a Jeep Rubicon and it had a locking front and rear diff., but I ended up trading it before I changed out the fluids. My new truck doesn't have the limited-slip, so I don't need them anymore. I'd like to get $10 for both, and I can ship them to you if ya want.
Old Oct 22, 2008 | 01:36 AM
Mahadigus's Avatar
Mahadigus
If you read the specs of the mobil 75/140 you will see that it has a friction modifier built into the fluid therefore mobil doesn't even offer a friction modifier separately.
