2005 Dakota Amp
Old Oct 23, 2008 | 12:49 PM
magnumATL's Avatar
magnumATL
Thanks ya'll. It just a 2d. I'm goin to replace the original amp with this 4000w. Someone told me that I might not get enough power for the 4000w amp becase i also have a hypertech chip, and a CB radio installed. Will I still be able to pump enough electricity for everything? I thought it would but my friend has owned 3 dakotas
Old Oct 23, 2008 | 01:32 PM
PEPPERHEAD's Avatar
PEPPERHEAD
You can't replace the amp. You have to bypass it when you install an aftermarket HU and such because of the trucks electronics. Not sure who sells the bypass harness. Got mine from Crutchfields when I bought my HU. Amp is located behind the front passenger kick panel.
Good luck. Pretty easy process for the most part.
Old Oct 23, 2008 | 03:20 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by ericemery
he's just stating the obvious biller...
per channel is the easy way to see if they will work with any aftermarket speakers...
All that I see when I read this is blah blah blah, he only asked how many watts it was...
and what in the world are you going to use 4000 watts for?
x2
Damn I think he is gonna be running like 3-4, 15 inch squares
Old Oct 23, 2008 | 04:10 PM
magnumATL's Avatar
magnumATL
the 4000W are for my subs i had in my old dakota. In my '95 i just replaced it. How much does a bypass harness cost?
