lighting for 08's
Old Nov 18, 2008 | 08:00 PM
the_balls's Avatar
the_balls
Default lighting for 08's
just wondering if anyone has upgraded the headlights on their 08 yet. i bought some silverstars today for mine but the god damn things wouldn't fit. they're the same bulb but they have this extra seal at the base that won't clear the red seal on the stock lens assembly. i just took 'em back because in my opinion $65 light bulbs shouldn't have to be screwed with to make 'em fit. so......who's done what?
brad,
tired of buying parts for the 08 that don't fit.
Old Nov 18, 2008 | 08:24 PM
the_balls's Avatar
the_balls
i'm pretty sure it had both numbers on the package, said H13(9008)ST
unless i'm mistaken. maybe i'll try a different set if i can find something. owning an 08 sucks, none of the parts i buy fit and i'm tired of being bone stock
Old Nov 18, 2008 | 08:25 PM
paul05dak's Avatar
paul05dak
stock seal on the light assembly?? What I think happened is that the red seal is from the bulb you were removing. there shouldn't be a seal on the assembly. Just on the bulbs. (I know, that happened to me when I put in silver stars before the projectors)
Old Nov 18, 2008 | 08:40 PM
the_balls's Avatar
the_balls
well ain't that a kick in the pants. i suppose i'll try it again then in a while, things are a lot funner to take apart than they are to put back together.
Old Nov 19, 2008 | 07:58 PM
the_balls's Avatar
the_balls
well i ended up getting a set of the piaa xtreme white plus bulbs and put 'em in today. they're only $5 bucks more and i've heard they're a much better product. they look pretty good but now i gotta do something about those fogs too
Old Nov 19, 2008 | 10:00 PM
the_balls's Avatar
the_balls
these ones are definitely better than stock but i'm still not satisfied. i want them tilted up higher so they light up more than 20 ft. in front of me. soooooooo.......any one know how to do that? is that adjusting screw on the corner for height or left to right adjustment? or do i have to shim it or something
thanks
Old Nov 20, 2008 | 08:51 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I had to do it on my 07, just a tad higher! They are at a good height now, I can see and no cars are flashing me when I am on low beam, so its all good. You are going to need a star bit, to do it, I forget the size...
