Getting nitrous installed by the middle of Dec
Old Nov 24, 2008 | 10:53 AM
User's Avatar
User
Originally Posted by ericemery
dont you have a cardomain page for that beast?
ya i cant remember my login and its not updated
Old Nov 24, 2008 | 11:28 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Damn slacker...
Old Nov 24, 2008 | 01:16 PM
donkeypunch's Avatar
donkeypunch
King Jackass
NO! No dry shot. Your factory ECU will not be able to properly adjust the fuel and timing trims to account for the nitrous. A wet kit will be a better choice.
Also, like mentioned above, purchase a purge unit and bottle heater. This will give you a faster response at the "hit" of the throttle. Also, for down-track performance, the bottle heater will continue to deliver the full shot and keep the nitrous pressure at a constant.
Old Nov 24, 2008 | 01:46 PM
lghtngblt02
Not only that, early detonation (backfire) scares the sheit outa me with nitrous and has the possibilty to pop the top (intake manifold) on the engine...
Old Nov 24, 2008 | 03:01 PM
lghtngblt02
Yeah I think you are right Eric, if I remember right... lol
You bet its not pretty...
Old Nov 25, 2008 | 01:15 PM
donkeypunch
King Jackass
I think Zex has its own kind of fuel management... I think Mike had to tap in to the shrader valve on the fuel rail for it to get accurate readings on pressure. (presumably)
but detonation scares the heck out of me too... I have seen a lot of older cars die by the bottle, its not a pretty sight.
But a good install is going to take into account a/f and fuel pressure...
Yes, the shrader valve should be a 1/8" NPT fitting. This will allow a 1/8" NPT to -4 flare male to be used as a fuel supply.
The only thing that you may want to consider is a fuel pressure gauge. Even though the ZEX kit has a fuel pressure saftey switch, you may want to visually be able to see a drop in fuel pressure. This will help understanding ACTUAL pressure drop, instead of seeing a voltage value.
