2005 Dakota.. no power to the washer pump
I have a 2005 Dakota 6cyl, AT, 2wd. The washer pump doesn't work. I've verified that the pump is good and that I'm NOT getting current to the pump. Are there any fuses/relays for just the pump? I've tested the wiper and intermittent wiper fuses and relays and they are good. I'm hoping there is some other fuse somewhere that I'm not aware of that is bad. If ths is not the case, would the next step be to replace the multi function stalk? If so how difficult is that? Any/all replies are appreciated. Thanks
i would say the stalk has a broken wire in it somewhere. try using the blinker and using the washer pump in both the left and right mode. or just hook up an aux, switch to the pump. but inside the engine compartment is the fuse box that tells what fuse is for what. might want to pull the fuse to see if it is good.
