will this fit.... stereo questions
Old Feb 5, 2009 | 10:21 PM
Altair's Avatar
Altair
Dak attack!
Originally Posted by BAdassR/T
alright so im pretty much stuck with the flip out ones or do they make 1.5's in dash screens?
Just cut the bezel, if you pull it off and look behind there I think a double DIN will fit right in once the bezel is cut, either way can't hurt to measure and see. IMO a double DIN looks much cleaner than a flip out.
Old Feb 5, 2009 | 10:24 PM
BAdassR/T's Avatar
BAdassR/T
yeah i know i really dont like the look of the flip out.....
Old Feb 5, 2009 | 10:30 PM
Altair's Avatar
Altair
Dak attack!
I cut my bezel with a Dremel at 1 in the morning when I was tired as hell and only screwed up 2 spots a little bit. If you take your time and follow measure twice cut once you should be fine.
Old Feb 5, 2009 | 10:41 PM
mikeybiker's Avatar
mikeybiker
Not sure on the 1.5 ones. I have a flip and its alright, but i wouldent get one again. The worst part is that it covers the vents. That, and if you flip it in and out to many times the little motors dont like moving anymore. I'm would just cut and fiberglass the dash to fit a double din.
Old Feb 5, 2009 | 10:45 PM
BAdassR/T's Avatar
BAdassR/T
well i have a dash kit which would prob be easy to hide any mistakes.... but other then a little trimming theres not much to it..?
Old Feb 5, 2009 | 11:12 PM
Altair's Avatar
Altair
Dak attack!
Well like I said pull it off, pull the radio and measure the area behind first, I'm pretty sure you'll have no issues fitting a double DIN in there but better safe than sorry. If the measurements are fine then yeah you'll just need to trim the bezel, that's all I had to do for the mygig install.
Old Feb 5, 2009 | 11:27 PM
BAdassR/T's Avatar
BAdassR/T
got ya thanks!
Old Feb 6, 2009 | 09:33 AM
superdak05's Avatar
superdak05
just make a cardboard cut out of what you would like. then tape it to the radio bezel and see how much cutting you will need to do
Old Feb 6, 2009 | 01:18 PM
BAdassR/T's Avatar
BAdassR/T
yeah a good thats a good start.... im gonna have to do that!
Old Feb 6, 2009 | 03:00 PM
Altair's Avatar
Altair
Dak attack!
Yeah don't do what I did and draw on the black plastic with a pencil so you can barely see the line before you start cutting, nevermind when there's disintegrated plastic flying everywhere
