Can foglights be mounted on top of bumper?
Old Feb 24, 2009 | 07:58 AM
object16's Avatar
object16
Default Can foglights be mounted on top of bumper?
on a 2008 Dakota? I have 2 Hella foglights, and 1 Hella driving light, and I would like to just drill into bumper and mount them with a nut and bolt. Will this work? Is there any problem with the plastic covering on the bumper?
Old Feb 24, 2009 | 08:10 AM
wyattc329's Avatar
wyattc329
what we all have been doing is drilling into the cross bar in front of the radiator... it just has to shine through the grill then... as for the bumper... i don't think they are sturdy enough...
Old Feb 24, 2009 | 08:54 AM
snipingdude's Avatar
snipingdude
yeah i dont think its sturdy enough either it feels too flimsy..
BTW what do you guys wire them up to? your fogs?? ?
Old Feb 24, 2009 | 09:32 AM
wyattc329's Avatar
wyattc329
i put mine on a switch... since i don't have the factory fog light system...
Old Feb 24, 2009 | 10:04 AM
biker_ahoy's Avatar
biker_ahoy
I have see this and seems to work, I would put a lightweight plate under the bumper to give some strangth so the bumper wont flex to much, but it should work
Old Feb 24, 2009 | 11:01 AM
paul05dak's Avatar
paul05dak
I installed my driving lights on the cross member but didn't do any drilling. There are 2 bolts on each end of the beam and I removed the inside one and used that. Perfect placement. They are hooked up by a 30 amp toggle switch in the cab. looped with the positive on the battery and then grounded to the chassie. Really easy install.
Old Feb 24, 2009 | 11:16 AM
01dodge's Avatar
01dodge
Will u have enough room to open your hood with the lights mounted on top the bumper?
Old Feb 24, 2009 | 12:13 PM
object16's Avatar
object16
I'm going to try to drill, and see what happens. I'll make sure the light is forward enough so the hood will clear on opening. and possibly put in a reinforcing bar of galvanized steel if i can figure out how to squeeze it in between the plastic and the metal.
Old Feb 24, 2009 | 01:40 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
why dont you try to make brackets that connect to the grill frame, so when you open the hood the lights go up with the grille. When you close the hood they will sit where you want them to sit. You probablly won't have to drill at all if you use existing mounting points on the grille frame.
Old Feb 24, 2009 | 02:35 PM
snipingdude
yeah and welcome to the forum lol
