E-fan's on
Old Mar 8, 2009 | 11:29 PM
mprohr's Avatar
mprohr
The DERALE / SPAL unit enables the system to operate automatically correct???? Does it get it's signal from whatever told the fan clutch to engage? Sorry, not so up to date on this topic. It seems reliable enough. But I don't want it to be something that gives the wife trouble...or screws up on a long trip. She had trouble with the light switch.
Old Mar 9, 2009 | 02:03 AM
Altair's Avatar
Altair
Dak attack!
The DERALE Eric is talking about needs to be adjusted once. After that it will automatically come on at the correct temperature, it will then run the fan until the temp drops to (not 100% sure on this number) 10 degrees less than the turn on temp. It also has an input for the AC + so it will turn the fan on when the AC is on.
Old Mar 9, 2009 | 07:54 AM
dakolorado's Avatar
dakolorado
The derale comes preset to 180 degrees, NO Adjustability, it then shuts off at 170 deg farenheit respectively. 30 bucks online.
Oh yeah, NICE NUMBERS!
Old Mar 9, 2009 | 09:38 AM
curtiplas's Avatar
curtiplas
Originally Posted by BAdassR/T
haha yes!
i want to do it eventually..
just dont want to run into problems never done one before............
Yeah +1 on that the only reason I haven't done one yet is because I'm not THAT savy at cars... I mean I can do basic stuff and anything I have directions for... but idk jack about electrical or exactly how the fan system works in a car/truck... so I'd do it, I just don't trust myself... same reason I have a 180 T-stat which I've had for 2 years and Haven't installed... or why I haven't painted anything myself on the truck... I'm slowly working up the courage to do the gutter guard grille LOL... I just don't want to break anything...
Old Mar 9, 2009 | 09:51 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Eric, what is used for a signal to activate the fan? Are you using an entirely new temp sensor, sending unit?
Old Mar 9, 2009 | 11:37 AM
dakolorado's Avatar
dakolorado
derale for 30 bucks will set the temp to 180 automatically turning on the fan when the coolant gets over 180 and shuts off when it reaches 170 degrees. easy wring job. The derale also comes with a wire you tap for the a/c + to operate the fan when the ac is running. (needed for the condesor on the front of our trucks)
Remember the fan that this is replaceing was run off the serpentine belt using a centrifical clutch not an electrical one, so you have to add the derale or equivalent to operate the fan.
20 amp fans can be had for under 50 bucks so this entire mod should be under 80 bucks.
Old Mar 9, 2009 | 11:38 AM
BAdassR/T's Avatar
BAdassR/T
haha thats the thing i am really good at pretty much everything.. ive done it all.. ill just have to read the how to to see how to do it!
Old Mar 9, 2009 | 01:34 PM
snipingdude's Avatar
snipingdude
Your like a mirror image of myself *sigh* lol
Old Mar 9, 2009 | 01:50 PM
BAdassR/T's Avatar
BAdassR/T
oh man so if we do, do these i guess im doing both myself -sigh-
Old Mar 9, 2009 | 02:53 PM
snipingdude
haha noooooo way dude.....its a team Efoort!!!!
