noises from the front end
Old Mar 15, 2009 | 07:35 PM
themoneyshot's Avatar
themoneyshot
Default noises from the front end
when i turn either left or right to almost full lock i get a grinding noise. do you think it is the tie rod ends, upper ball joints, or lower ball joints?
i believe that i can change the tie rod ends, the upper ball joints require a new control arm assy, what about the lower ball joints?
truck is out of warranty so this is out of my pocket. however i do not mind casting a large net and replacingextra parts while the tirea are off.
i appreciate any answers
Old Mar 16, 2009 | 01:08 AM
dakolorado's Avatar
dakolorado
Check your rubber boots on your tie rods and your ball joints. If you have any breaks and missing grease you will quickly find your culprit. Dont forget to check your rack and pinion as well, that entire assembly can be expensive but I have found them online for 100ish bucks.
Old Mar 16, 2009 | 05:49 PM
themoneyshot
thanks
i took off the tire and the boots on the upper ball joints are completely missiing. i must have torn them when replacing the struts. i smeared some grease around the ball joint, is this a waste of time or can i putoff the inevitable a while ?
Old Mar 16, 2009 | 07:54 PM
Altair's Avatar
Altair
Dak attack!
You should probably get that changed out soon, unfortunately we can't get aftermarket ones yet (possibly never) so you'll have to get it from the dealer and you have to replace the whole upper arm, it sucks.
Old Mar 17, 2009 | 06:59 PM
phil74501's Avatar
phil74501
I have some ball joints, I believe both upper and lowers, through a local brake shop. Moog parts, been waiting for three weeks. Everytime I call them they check and say Moog says they are being made and will be out anytime.
Old Mar 18, 2009 | 01:59 AM
dakolorado's Avatar
dakolorado
Originally Posted by themoneyshot
thanks
Your gonna want to get grease on those everyday that it rains or keep an eye on it once a week til you can get them replaced. They make boots to repair but if its squeeking already or making noises you need to replace asap. failure is mighty dangerous.
ask this guy.
Old Mar 18, 2009 | 02:17 AM
f0x672's Avatar
f0x672
sweet pic, makes me feel all good inside to know my ball joints are shot and i gotta drive with em for a few days.
Old Mar 18, 2009 | 09:54 AM
themoneyshot
thanks for the picture. better have my wife drive the truck until i get them replaced. i was wondering how well those boots work. they glue together correct?
phil, how are we to replace with moog, definitely an upgrade, because ours are anintegral part of the a arm?
Old Mar 18, 2009 | 01:26 PM
sdsdsd's Avatar
sdsdsd
It could be the stops, they need grease once in awhile or they make noise when you lock left or right.
