2" block lift in rear with Ranchos?
Old Apr 15, 2009 | 12:51 PM
Nateward's Avatar
Nateward
Default 2" block lift in rear with Ranchos?
Do the ranchos have enough travel if 2" spacer blocks are used in the rear for a lift?
Thanks!
Old Apr 15, 2009 | 02:11 PM
Blacksport's Avatar
Blacksport
I think there are a couple guys here that has that done. Monkeywrench, you have that, don't you?
Old Apr 15, 2009 | 04:35 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
I actually have KYBs in the rear right now, that are made for the stock setup. The ranchos should be the same length as the stock shocks, and the stock shocks work with the 2" blocks, so I would say yes they will work.
