A frame water leak
Old Apr 29, 2009 | 11:21 AM
biker_ahoy's Avatar
biker_ahoy
Default A frame water leak
Has anyone had leaks on the front A frames, Just got a new windshield installed and took it back got it tested and then removed and reinstalled, so far so good but was wondering if anyone else had experianced this??
The water was coming into the cab from the top bolt on the passanger side took the cover off and couldn't trace it anywhere.
Was kinda worried as I just install tweeters into the A arm covers
Old Apr 29, 2009 | 12:52 PM
Altair's Avatar
Altair
Dak attack!
Can't say I've noticed any leaks on mine other than when the back half of the cab was all smashed up
Old Apr 29, 2009 | 02:02 PM
Blacksport's Avatar
Blacksport
had the exact same problem. I put some clear silicone on the outside in the groove between the w/shield and roof header, and it hasn't leaked since.
Old May 8, 2009 | 11:20 AM
biker_ahoy's Avatar
biker_ahoy
Default Still leaking
Well we got a little rain the other night and it's still leaking. dropped the truck off again at the glass shop and they have their veteran guy in today, he's gonna look at the truck and see if he can find the leak. hopfully its found this time.
this it the thrid vistit to the glass shop and I also took it to dodge and they looked at it and couldn't find anything. Grrr.
Old May 9, 2009 | 02:00 AM
ramos160's Avatar
ramos160
I have water coming in my truck but it's leaking from somewhere underneath the dash, below the windshield. I took it to two mechanics and neither one were able to fix it. I am glad you were able to get that leak taken care of, they are a pain to get fixed.
Old May 9, 2009 | 04:58 AM
graythang's Avatar
graythang
If it isn't an AC condensation leak then it just may appear to be coming from under the dash. I say that because my 06 water leak also looked very much as if it was coming from under the dash but was actually dropping down the A pillar into the dash and then to the floor mate. They found a porly sealed factory weld up in the top area of the door frame jam structure. With Florida rains I trusted it was fixed correctly since it never leaked again.
