2008 dodge dakota stereo help!
Old May 29, 2009 | 04:35 PM
mprohr's Avatar
mprohr
Oh yeah, almost forgot. Your best friend when doing door speaker installs will be strip caulk. Get 3M strip caulk from the local autoparts store. They are 1' black strips that come in a blue box. It is about $20 for a box of it....and I almost used the whole box when doing my 4 speakers. Use if for gasket material in-between everything, re-attaching the plastic door liner, or deadening panels and plastic rivets.
Old May 29, 2009 | 09:12 PM
mprohr's Avatar
mprohr
Like you said, "Idiot at Best Buy". Yes, it does stick to everything, which is why it works so well, and when used properly is a great tool. Besides, it's not that bad, and is a lot easier to work with than deadener.
Another trick is to stuff insulation under the white mat on the inside of the plastic door panels to faten them up, cheap sound deadening and reduced door vibration.
Old Jun 1, 2009 | 12:28 AM
snookn42's Avatar
snookn42
Apparently it already had some deadener in there. ANd the bass especially sounded really good as well as the sound in the stock speakers. I gave my fiance the pioneer and today threw in the pioneer speakers, the front have 3 way and the bacl have 4 way speakers. They sound much better, and there is a huge difference in the sound from the stock speakers. The bass is even better and the the better part is the rest of the music is mch more clear. There is little to no rattling from the bass. I wish I could find info on if there is a amplifier in the truck, though, I cannot figure on the bass sounding that good without one...
Thanks guys, if anyone knows about the amp let me know!
Old Jun 3, 2009 | 10:53 PM
James3's Avatar
James3
Can you please tell me what the wiring diagram is like for the 2005, I am trying to install a c.d. player in my 05 but the wiring harness I bought doesnt match up.
https://dodgeforum.com/forum/3rd-gen...ml#post1690499
if you can reply there, I will check there back...im not very computer literate, sorry!
(Sorry, not trying to jack your thread, but I read you installed a deck in an 05 and thought maybe you can help out)
Old Jun 3, 2009 | 11:24 PM
mprohr's Avatar
mprohr
You may have to be more specific on the trim level of your truck. I think there are at least 3 possibilities on wire harness.
