drain plug on 05 dakota
Old Aug 17, 2009 | 02:42 PM
daterxies's Avatar
daterxies
Default drain plug on 05 dakota
Where is it? dont say in service manual.... last time i made a guess it ended up being the tranny (on a diff vehicle lol) the oil drain
thank you
Old Aug 17, 2009 | 02:47 PM
daterxies's Avatar
daterxies
is it the one facing passenger tire?
Old Aug 17, 2009 | 03:08 PM
Dak_in_Black's Avatar
Dak_in_Black
thank you
The drain plug for the oil is located just above and just in front of front cross-brace...the oil dumps directly onto this and pours all over the place...
Old Aug 17, 2009 | 03:19 PM
daterxies's Avatar
daterxies
gotcha... and as i found out if your doing this with just a jack and the bolt is super tight good luck... i been at it for a while now and i cant even crank it at all, and cant get my bar in there i use for other cars... figures. any suggestions for a super tight bolt in a place near impossible to get? lol
Old Aug 17, 2009 | 04:08 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
hmmm I remember the factory filter being a bear but never the plug... good luck
Old Aug 17, 2009 | 04:20 PM
popsnbeer's Avatar
popsnbeer
I usually can get it w/ a 1/2" drive ratchet. Was the truck recently running? If it's warm, then it could be a little harder to get off (just a thought, no actual science here). Also, make sure you are turning the right way ;-) I know it sounds stupid, but when you're upside down there things can turn you around.
Old Aug 27, 2009 | 06:47 AM
sdsdsd's Avatar
sdsdsd
It's a really messy job the oil goes all over because it dumps on the cross member. Make a ramp for the oil to flow onto. That will really stop the big mess. It hardly seams worth the trouble to do it yourself. If you look around someone is running a special for an oil change someplace. In reality it will cost you the same to have a shop do it vsd you doing it. Then you don't have to take the oil to get recyled.
Old Aug 27, 2009 | 10:47 AM
Baby_Ram's Avatar
Baby_Ram
ratchet and pipe and both were a beast for me on the first time. never had a problem after that.
