Stock 17" x 8.5 Rim whats the offset on those
Old Aug 31, 2009 | 06:49 PM
biker_ahoy's Avatar
biker_ahoy
Default Stock 17" x 8.5 Rim whats the offset on those
I'm looking at new rims. I have the stock 17" plastic chrome covered ones.
What do I need to know?
what the Offset of the stock rims?
I believe the stocks rims are 17" x 8.5 right?
what's the bolt # I need 5 bolts and that other # for the spacing between the bolts, right?
Old Aug 31, 2009 | 09:00 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
The stock rims are no wider than 8" and they are a 5.5 offset.
Old Sep 1, 2009 | 02:48 PM
biker_ahoy's Avatar
biker_ahoy
What would be the "back spacing" on the stock rims?
will those work? or am I way off
#175-6885U
rim 17x8
back space 4 7/8
offset +10
Bolt pattren 5-5.5
Cap 89-8125
Bore 108mm
Load Rate 2200lbs
if that size is off which ones if any will work? Sorry I'm not good with figuring out the rim specs
http://www.ultrawheel.com/pdf/rims/175.pdf
Old Sep 1, 2009 | 03:52 PM
canadiandodge's Avatar
canadiandodge
i have a set of ultra wheels the mamoth i think they are similair to that not a 100 percent sure
they are 18 by 9
http://www.ultrawheel.com/pdf/rims/227b.pdf
not sure if this helps hope it does
