Superchips question
Old Sep 11, 2009 | 09:28 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Eric, you pimp... dont let Jess see this post or for that matter don't get caught I would hate to see what would be done to you by the man of the house! haha
Old Sep 11, 2009 | 01:12 PM
bain64's Avatar
bain64
Originally Posted by lghtngblt02
Yes, with the 3865 you, but he forgot to mention its only for WOT shift
Well that is very misleading from what the vendor said, as I did not include the earlier part of the email where I was asking about daily driving at between 2-3k rpm shifts. Below is the full context of the email
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Matthew,
The shift points can manually be adjusted and fine tuned in each setting of the quick tune.
Jason Misiak
1-888-227-2447
Sent: Thursday, September 10, 2009 10:50 AM
To: Technical Account
Subject: RE: A new Contact Us Form has been submitted at Superchips.com.
Can the shift points be manually adjusted, or are the preset tunes the only thing that adjusts the shift points?
Thanks
I am getting closer to purchasing, just like to do my research.
From: Jason Misiak [mailto:jmisiak@Superchips.com] On Behalf Of Technical Account
Sent: Thursday, September 10, 2009 9:47 AM
To: Matthew
Matthew,
Your adjustability with the tuner is:
Shift points, shift firmness, speed limiter, rev limiter, and tires (22.5-42).
So to answer your questions:
1)It’s adjustable.
2)Most likely the guy raised the rev limiter
3)There are different pre set settings for different tunes
Jason Misiak
1-888-227-2447
Sent: Wednesday, September 09, 2009 11:59 AM
Great, only gas vehicles.
The only other thing I am concerned about is the 1-2 shift. I have read from other reviews from someone with the same model/year truck that regardless of which tune they chose while running the flashpaq 3865, that it did not shift into second gear until 3000 rpm.
  • It seems high, Is this adjustable?
  • Did the guy just have a lead foot or something? Stock shifts at 2000
  • Are there different shift points within the different settings, 92 tune vs Mileage tune ?
Thanks for your quick response regarding my first question.
2006 Dakota 4.7L
Sent: Wednesday, September 09, 2009 10:49 AM
To: Matthew
Matthew,
It really depends do you have a gas and a diesel vehicle? If the answer is no you only have one or the other then a Flashpaq is best for you. The Cortex just roles both diesel and gas into one tuner.
Jason Misiak
1-888-227-2447
From: CustomerCare@Superchips.com [mailto:CustomerCare@Superchips.com] On Behalf Of matthew
Sent: Wednesday, September 09, 2009 11:36 AM
Subject: A new Contact Us Form has been submitted at Superchips.com.
Subject : Flashpaq vs cortex
What is the difference between the two? Where can I get more detailed information at? Is there a user manual or something online I could read through?
Old Sep 11, 2009 | 01:33 PM
lghtngblt02
hmmm, weird...
The quick tunes dont give you adjustability other than I think the rev limiter. Maybe on a different vehicle because these are multiplatformed. I run into a problem with this but from what SC said its because I didnt drive it enough for the computer to learn. My problem was it was bouncing the rev limiter at WOT and it wouldnt shift, I figured it out after doing it a second time, and blipping the throttle which allowed it to shift, it was way weird. It seemed like the rev limiter was lower than the WOT shift rpm. Granted I did only set the rev limiter a lil higher than stock then. Now the advanced tunes give you different options such as the WOT shift rpms along with the tire size, and the rev limiter. Anyone else wanna chime in? Mine doesnt have any adjustment for the normal shift points or shift firmness.
BTW I just did a test coming back from lunch and my 3865 with the advanced 92 tune and its shifting 1-2 at approx 2000-2200 rpms under normal driving (mild acceleration) conditions, now as for the rev limiter I have it set at 6200 and WOT shifts are 1-2 at set (IIRC) 5800 rpms and 2-3 is the same as the 1-2.
Old Sep 12, 2009 | 10:09 AM
bain64's Avatar
bain64
Thanks for the test lightning. That was my only apprehension.
Did your problem ever fix itself by driving on it further? I won't be at WOT very often, unless I am late for work or need to merge.
Old Sep 14, 2009 | 05:29 PM
lghtngblt02
I never let it, I went back and did the advance tune instead of the quick and retuned the truck
Earlier I meant 91 tune, not 92, my error.
Old Sep 14, 2009 | 05:55 PM
bain64's Avatar
bain64
One of my ebay auctions ended early with the buy it now price! If any of the other 7 end early I can get my 3865 ordered sooner...
Old Sep 14, 2009 | 09:38 PM
dodgetrucker75's Avatar
dodgetrucker75
i just ordered one today, was buy it now for 299.99 + shipping, but made an offer and got it shipped for 289.99. and it is new in the box, cant wait....
Old Sep 15, 2009 | 07:23 AM
bain64's Avatar
bain64
Was that from Lopers speed? I don't know and don't care how he gets those 100 cheaper than anyone else in the world, but he will have my business.
