Looking to get beefier tires for a stock 2005 Dodge Dakota
Old Sep 11, 2009 | 11:08 AM
camiltster's Avatar
camiltster
The back of the truck is sitting a little higher because I have installed airbags in the rear because I tow a trailer from time to time. In the picture the airbags are about 15 psi. It is an easy way to lift the back of these trucks and a very simple installation. Total installation time was less than 1 hour with simple tools. With the Firestone airbags I put on I can lift the rear up to about 6".
Old Sep 12, 2009 | 08:06 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Where is a good place to get the firestone airbags?
Old Sep 13, 2009 | 12:17 PM
camiltster's Avatar
camiltster
I got them at a local truck specialty shop. Well actually they specialized in big rigs but they were able to order bags for smaller vehicles as well. The set ran me about $270 without a compressor. However, it came with fittings and hoses so u can mount the fillups wherever you want. I mounted them on the rear bumper for easy access.
Old May 12, 2018 | 11:12 PM
dakotaiowa's Avatar
dakotaiowa
Hello,
I am new so please be patient with me. I was reading a lot of this and other threads and wanted to clarify something I read. I have a 2005 Dodge Dakota SLT (4.7) 4x4, and it is all stock. My current tire size is 245/70R16 and I want to put 265/70R16 on it. Will there be any rubbing due to this increase of tire size, or will it fit without rubbing? I really don't want the rubbing experience. Thank you.
Old May 13, 2018 | 08:23 AM
dakotaff's Avatar
dakotaff
Originally Posted by dakotaiowa
Hello,
Wow, how did you find this old thread?
Anyway, yeah, 265/70/16 was a stock size tire option, there will be no issues fitting them on, none at all, so go right ahead.
Welcome aboard.
Old May 15, 2018 | 04:02 PM
FaceDeAce's Avatar
FaceDeAce
..... just because I had and old set lying around, I tried 265/70 R17 - and those rub in the front fenders on even slight turns. Therefore anything smaller than that will fit fine. The stock tire size, largest available, are what came on my '05 Dakota is 265/65R17. Despite having plenty of other standard truck sizes available, I finally gave in and ordered a brand new set of General HTS60 for it in the correct size. Further, as fyi for the winter I use 245/70R17 blizzak
Old Feb 13, 2022 | 05:42 PM
Marty Schmidt's Avatar
Marty Schmidt
Default 2005 Dodge Dakota
Hello,
I am running 265/70R16 with no rubbing.
Old Aug 26, 2022 | 12:55 PM
Hasitualls's Avatar
Hasitualls
I would recommend getting some all-terrain tires. They will give you good traction in the snow and be beefier than your regular tires. As for tire size, I think you can check https://carwheelbase.com/dodge/dakota/ for more information. Hope this helps!
Old Feb 22, 2023 | 09:10 PM
Codybarber1315's Avatar
Codybarber1315
Sorry to bring this thread back to life but I have a 05 quad cab 2nd can it still fit the 265/70/16s I have looked everywhere online and it seems the 2nd and 4wd have the same clearance and all but wanted to be sure
Old Feb 22, 2023 | 09:37 PM
dakotaff's Avatar
dakotaff
Yes, 2wd and 4wd have the same exact clearance. Your 2wd will fit those 265/70/16 tires perfectly. With stock wheels, there will be no issue at all.
Unless, of course, you change your wheels to some aftermarket wheels with some crazy offset.
Welcome aboard.
