Is it bad to run without Stabilizer link
Old Sep 18, 2009 | 02:34 PM
Cuban11182's Avatar
Cuban11182
Default Is it bad to run without Stabilizer link
Was replacing the struts and snapped one. Just placed them both on order, but was wondering what the thought was. I realize we might have a little more body roll than normal, but I don't think it will matter to much.
Any ideas?
Secondly, How do you remove the knuckle from the upper control arm. That thing is a PITA!
Old Sep 18, 2009 | 05:09 PM
Q-TIP's Avatar
Q-TIP
You can run it without your end links, however you will notice a significant decrease in on-road performance. However you will also likely see an improvement in articulation off-road. I would say get them fixed when time allows, but dial back on formula one cornering (cause we all know the Dakota is a handling MONSTER ha ha)
Old Sep 18, 2009 | 06:19 PM
Cuban11182's Avatar
Cuban11182
Thanks Eric and Q-Tip.
Side note Eric are the cams in yet?!?!
Old Sep 22, 2009 | 10:24 AM
rgraider's Avatar
rgraider
I used a pitman arm puller to break the knuckle apart.
Old Sep 22, 2009 | 01:45 PM
Cuban11182's Avatar
Cuban11182
Exclamation
Ordered one and two replacement links. Just got out of surgery 3 hours again, so I won't be putting it on anytime soon.
