545RFe Transmission Pan Removal...
Old Oct 2, 2009 | 05:19 PM
Jericho's Avatar
Jericho
Default 545RFe Transmission Pan Removal...
Can the pan be removed without removing the cross-member?
The shop manual doesn't mention removing the cross-member.
Old Oct 2, 2009 | 06:11 PM
projektdirtfab's Avatar
projektdirtfab
i removed mine but later found that just taking out the tranny mount bolts and jacking the tranny up a bit does the trick.
Old Oct 3, 2009 | 04:22 PM
Jericho's Avatar
Jericho
There is some clearance between the pan and the cross-member... What prevents removal of the pan with the available clearance?
Old Oct 4, 2009 | 05:25 AM
projektdirtfab
the pan has to drop down farther to clear the filter. unless your salad fingers and can pop the filter off at the same time... better off just zipping 2 bolts loose and lift the tranny a couple inches. no biggie
Old Oct 4, 2009 | 04:33 PM
LB's Avatar
LB
or drop the crossmember, takes about 10 minutes, 4 bolts and 3 nuts to the trans drops right our and everthing is clear.
LB
Old Oct 5, 2009 | 03:27 AM
projektdirtfab
that's what i do. i would sacrifice a few extra minutes if it meant having a better work space.
Old Mar 8, 2020 | 10:02 PM
Lynnette Dicken's Avatar
Lynnette Dicken
The shape of the pan and available clearances. You HAVE to have additional clearance to get the sucker out of there! I removed the 4 bolts and jacked the back end of the transmission a little more than an inch and found one and one way only to get it out even then!
