Bad vibrations
Old Oct 26, 2009 | 11:28 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by sleds
Could you guys explain that just a little bit more? I am trying to picture that and can't.
This is off an 8 lug ram, but it gets the point across.
Its the retaining clip that holds the discs and drums on during assembly. At first they didnt bother my truck, but on the second or third rotation I developed a shimmy that wasn't there until after I rotated the tires. It causes the rims to improperly seat. I took the rims back off, plucked the clips off, and then re-installed. The shimmy was no more.
Old Oct 26, 2009 | 11:41 AM
canadiandodge's Avatar
canadiandodge
ya i have removed those i was told to when i put my aftermarket rims on i noticed it then so i figured it was those rims not balanced now i am back to stocks and have the same vibrations just more intense now and thats with the stocks on
Old Oct 26, 2009 | 12:10 PM
boopadoopa's Avatar
boopadoopa
Im Having a vibration also? I thought it was my tires But i just had new ones put on and its still there. I get it around 40-60 MPH I checked the bearings, and universals? Nothing looks out of wack but not sure? Sprayed the universal down with PBblaster But doubt that would have done anything in the first place... Its frustrating with everything i have looked into?
Old Oct 26, 2009 | 03:28 PM
cramerica's Avatar
cramerica
Lightning - that is *exactly* what I was picturing. I think I'm off to Sears tonite to get a torque wrench...nice find on the pic.
Old Oct 26, 2009 | 03:49 PM
cramerica's Avatar
cramerica
Also, just read something very interesting in the service manual - vibration could be caused by excessive radial or logitudinal runout, in otherwords, wobbly/out of round tires or bent rims.
Old Nov 17, 2009 | 12:42 AM
05Dakotaho's Avatar
05Dakotaho
After having the differential pinion seal replaced at 35k miles by the dealer I experienced a vibration. Drove it right back and the tech that did the job admitted that he didn't torque the pinion yoke per spec.
Re-torqued per spec and vibration quit.
