Front end Rattle??????
Old Dec 17, 2009 | 08:26 AM
boopadoopa's Avatar
boopadoopa
Update.. I found my rattle that I started this post on.. Turns out it was a broken rattle clip on the brakes. 9 dollar fix . Amazing how loud the rattling sound is comming from the brakes. Now All i need to do is get new shocks and the other noise will go away..
Old Dec 17, 2009 | 11:29 AM
bain64's Avatar
bain64
Congrats on finding the noise. Still looking for my clunking noise.. I will check all the things mentioned here.
Old Dec 17, 2009 | 01:32 PM
boopadoopa's Avatar
boopadoopa
Mine also clunked on every bump last year and i replaced both lower ball joints and solved that issue... What sucks is no parts store carries anything for these daks
you have to go to dodge dealer with Vin number in hand... Im starting to hate my truck and am tinking of going back to a ram..
Old Dec 17, 2009 | 02:24 PM
05dakota4x4's Avatar
05dakota4x4
yea my upper ball joint went out went to the dealership they wanted $208 luckily i knew a body shop and got it for about $160 there price through the dealer
Old Dec 17, 2009 | 05:12 PM
bain64's Avatar
bain64
Do the lower ball joints usually fail sooner? Can I slide the boot aside and see if something is wrong? Or how do you diagnose which ball joint is bad?
Old Dec 24, 2009 | 12:04 PM
Erik Kuijvenhoven's Avatar
Erik Kuijvenhoven
jack it up check for play with a big steel bar
Old Dec 25, 2009 | 12:30 PM
tdister's Avatar
tdister
I had a pretty bad clunk coming from the front. Did shocks w/ leveling kit and put in new sway bar end links while I was at it.
Nothing seemed to be loose or broken upon disassembly, but the rattle/clunk is gone now...
