wheels
Old Dec 14, 2009 | 11:31 AM
dakotaff's Avatar
dakotaff
From the Dodge site Tech info site, both 16X7 and 16X8 have a 25.4mm offsets. Hope that helps a bit.
Old Dec 14, 2009 | 12:04 PM
Q-TIP's Avatar
Q-TIP
Perfect, thanks!
Actually, that doesn't make sense. If the factory offset is +25.4mm then the backspacing would be around 5". If that is the case then anyone with a 4.5" backspaced wheel should work and I'm sure I've seen guys on here that said a 4.5" backspace doesn't work with 265's
Old Dec 14, 2009 | 01:00 PM
dakotaff's Avatar
dakotaff
Hopefully someone can chime in on these measurements, Dodge site says 16X8X25.4mm, 16X7X25.4mm. Maybe this page can help.
https://www.rsracing.com/tech-wheel.html#backspace
I'm certainly no expert on these #'s. BTW, I have 265's on the 16X8's.
Old Dec 14, 2009 | 01:13 PM
Q-TIP's Avatar
Q-TIP
I do too, I will take my wheel off tonight or tomorrow and just measure them directly.
Old Dec 22, 2009 | 03:58 AM
Slick Dakota's Avatar
Slick Dakota
Q-tip what did you come up with when you measured your wheels?
And are you having any rubbing with them 265/75/16 on your stock wheels?
I am looking at these right now and here is there size
Offset: -12mm
Backspacing: 4.05"
Bolt Pattern: 5-139
Rec. Tire Size: 245/70-16 this is tire racks recommended tire, I want 265/75/16 good year Duratrack
Weight: 19.8lbs.
